Hi Guys,
went to this w/m today, keeps filling with water after p/sw clicks off, also keeps fill when set to drain. I opened up p/sw to look for sign of burnt contacts but it was ok. Could it be the module located in the bottom back of machine. Part number for p/sw and module would be helpful if this is the fault.
Very common module fault. Send it to Tony at EMW for repair, if you order a new one you will need to order an eeprom as well. Couple of different pressure switches, need serial number to ID, has it got the metal or plastic outer drum?
Pressure switch is a C00088393. Module is C0093157, Eeprom is C00089846.
would still advise sending the module to EMW, they will turn it round almost a soon as you can order a new one with a good saving on cost of new module & eeprom combined.
