indesit w12s
  • #10107
    Hello im having a problem with my indesit w12s
    The program dial is continuosly turning all the time and wont finish the cycle
    Any ideas.
    Andrew
    #138360
    Dave_Conway
    Re: indesit w12s
    The indicator lamp will also be flashing, if you count the number of times this, (in theory at least) indicates an error code.
    #138361
    Re: indesit w12s
    Yes
    The Red indicator lamp flashes 5 times
    Andrew
    #138362
    Dave_Conway
    Re: indesit w12s
    Water level control problem then as long as the code is accurate which they often aren’t 😕
    Possibly the pressure switch but I would recommend you call an engineer to verify this, check repairs@ and the directories for one.
    If you are to investigate further yourself, unplug 1st :plug:
    #138363
    Re: indesit w12s
    so were would i find these switches would they be around the drum,
    thanks for the help so far
    Andrew
    #138364
    Re: indesit w12s
    whitter wrote:so were would i find these switches would they be around the drum,
    It’s the water level control you need look for. (A Pressure switch connected to a thin black rubber hose) That hose or switch may be your problem??
    :plug: No peeking without cutting the power though, …..promise me? :zap:
    #138365
    Re: indesit w12s
    Hello
    Damn the screws on the back appear to be torq style screw heads
    Andrew
    #138366
    Re: indesit w12s
    whitter wrote:Damn the screws on the back appear to be torq style screw heads
    Darn!…now what 😆
    #138367
    Re: indesit w12s
    Great got one got the top off
    Looking inside…
    The only black rubber hose is a small 10mm style size tube on the right of the drum, its connected to what appears to be a white type of switch with a few wires connected to it, at the moment i cannot see where the bottom of this tube leads to somewhere at the bottom of the drum??
    Andrew
