Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit w133 door seal removal
- This topic has 11 replies, 6 voices, and was last updated 14 years, 1 month ago by
GaryB.
March 8, 2012 at 12:08 pm #68330
GaryB
ParticipantHi All,
I have taken off the washer top, removed the screws holding the dispenser and control panel, question is how do i remove the front panel to access the drum/seal wire?
Hope you can help,
GaryBMarch 8, 2012 at 12:37 pm #370639stevebunyan
ParticipantIndesit w133 door seal removal
If you remove the plastic panel with the knobs at the top and also the plastic plinth at the bottom which slides left once the screws at filter are removed, you will see 4 screws, 2 top 2 bottom, remove these and the frt will slide down and off.
Sent from Steves
iPhone using TapatalkMarch 8, 2012 at 1:50 pm #370640GaryB
ParticipantRe: Indesit w133 door seal removal
Thanks Steve,
Just one further question, how do you remove the plug from the filter to check inside? It undoes half a turn (water runs out) but thats as far as it seems to undo.
Cheers.
GaryBMarch 8, 2012 at 3:06 pm #370641Martin
GaryB wrote: It undoes half a turn (water runs out) but thats as far as it seems to undo.
That’s because there’s something inside preventing the filter from rotating. The only solution therefore is to remove the pump/filter unit complete and tackle the blockage that way.
March 8, 2012 at 4:19 pm #370642iadom
ModeratorRe: Indesit w133 door seal removal
stevebunyan wrote:If you remove the plastic panel with the knobs at the top and also the plastic plinth at the bottom which slides left once the screws at filter are removed, you will see 4 screws, 2 top 2 bottom, remove these and the frt will slide down and off.
This is an Indesit machine. :rolls: One piece cabinet, the front does not come off, you have to struggle from the top and front through the port hole. 🙁
It also has two different, non interchangable door seals. The only way to find out which one you have is to remove it to see what type of strap/band is holding the seal to the outer drum, it will be a spring band or a wire clamp band, just hope its the spring or you will rue the day you attemped to repair it. 😐
No screws in the plinth either, it just prises off. 😉
March 8, 2012 at 6:45 pm #370643kiddo66
Bent nosed pliers and fairy liquid.
March 8, 2012 at 7:04 pm #370644iadom
Apparently a large plastic bag tie as a ‘third hand’ helps as well. 😉
March 9, 2012 at 7:52 am #370645stevebunyan
That’s embarrassing I have just done 2 machines and would have swan they where Indesit. I really must get this new glasses or my memory checked.
Sent from Steves
iPhone using TapatalkMarch 9, 2012 at 8:15 am #370646Allsorts
Sent from Steves
iPhone using TapatalkSounds like a Bosch
George
March 9, 2012 at 9:02 am #370647iadom
Allsorts wrote:
Sounds like a Bosch
Have you nicked that from a VW Golf advert? 😀
March 9, 2012 at 6:26 pm #370648GaryB
Thanks everyone,
It took me three n half hours but I got there 😀 ! Steve: It was a 5p in the filter. As iadom mentioned the front panel is pressed on and it has the wire band 🙁 I used a tie wrap to pull the band together all the while wishing (as Kiddo66 mentioned) that I’d bought that pair of bent-nosed pliers last time I needed them years ago, it seemed a luxury at the time :rolls: So next shopping day guess what I’ll be buying 😆
Cheers
GaryB
PS: Don’t worry Steve, Indesit or Bosch, I appreciate the helpful and quick reply.March 9, 2012 at 8:26 pm #370649stevebunyan
I got my bent long nosed pliers from eBay for about £6.00 used them loads
Sent from Steves
iPhone using Tapatalk -
