INDESIT W133 heater element, leaks.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries INDESIT W133 heater element, leaks.
  • #44033
    deltra
    fitted a new element to this heap of tin, but i cant stop water pi$$!^g out of the seal 😕
    #279537
    Re: INDESIT W133 heater element, leaks.
    Sounds like you might have cut the seal on the sharp edge of the heater aperture. 🙁
    Mike.
    #279538
    correct heater? absolute nightmare getting the correct part number for those.
    #279539
    jonnieboy
    very carefully look along the seam of the tub just above where the metal bends out for the heater hole the metal tubs are prone to getting swiped by the inner drum at this spot and crack it easily gets mistaken as the heater leaking
    #279540
    deltra
    i think it is wrong heater, old one 17700w, new 1800w, and rubber seal looks slightly narrower :rolls: thanks guys.
    #279541
    deltra wrote:i think it is wrong heater, old one 17700w, new 1800w, and rubber seal looks slightly narrower :rolls: thanks guys.
    Must heat up pretty quick!
    Mike.
    #279542
    deltra
    😯 quite hot 😆
    #279543
    wilf
    I had one a couple of years ago and after a lot of head scratching it turned out that the tub WAS leaking where the metal was folded at the flange. magnifying glass and a light I’m afraid.
    the word “tin” sums it up
    wilf
