W133 washing machine. The main bearing (closest the drum) got water in and failed. I got as far as removing the aluminium bearing assembly (shaped like an X) from the rear of the drum and removing the water seal. Now I can’t get the bearings out of it at all – its as if they are superglued in. Are they supposed to be in so tightly and is there a special method or tool needed to remove the bearings.
