i have a problem with my washing m/c. when starting a program i always turn the machine on at the on/off button, then turn the program wheel to a black dot and wait for the 3 rapid rad LED flashes, then i turn the program knob to the desired program and it used to do the trick. now it simply gives 3 repid flashes when i try to start a program and then the light comes on and stays on but the program does not start and nothing happens whatsoever.
does any body have any ideas, or does the machine require binning? after all, it is a few years old now and had 2 new seals and a new drum in that time so it’s almost like triggers brush 🙂 but is it time to cut my losses.
thanks for the fast reply iadom, i have just been to check the brushes and they do seem to be quite worn but are still making contact witht the motor commutator. what does this sound like to you?
