Indesit W14 problem
  • #21809
    Vizbox
    After following a guide from here last week I successfully removed a hair clip from my washing machines filter and got it running again.
    Now my machine seems to be faulty again.
    After a standard wash cycle I was finding quite a bit of water in the fabric conditioner compartment. But now the fabric conditioner is not being released into the wash unless I use the ‘quick wash’. And then the compartment is full of water !
    I have run the washing machine on a 90* wash to try and clean any blockages.
    Any idea’s how to fix this ?
    #192609
    Re: Indesit W14 problem
    1) Remove drawer, remove conditioner cover and clean thoroughly, especially the tube into the cover and the tube through the base.
    2) Whilst the drawer is out, look up into the roof of the soap box. Again, clean thoroughly. Use a pipe cleaner or similar and prick through any holes which look clogged.
    Usually does the trick……..
    Vizbox
    Nice one thanks. Will give it a go 😛
