indesit w143 10 flashes Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › indesit w143 10 flashes This topic has 11 replies, 4 voices, and was last updated 19 years, 7 months ago by phil59. Viewing 12 posts - 1 through 12 (of 12 total) Author Posts August 28, 2006 at 2:25 pm #20359 phil59Participant hi everyone indesit w143 10 flashes changed press switch 4 times no different whats ***&!!!!* happening August 28, 2006 at 5:15 pm #186796 Penguin45Participant Re: indesit w143 10 flashes Hi Phil, Pressure switch problems…… http://www.ukwhitegoods.co.uk/modules.p … 0&start=15 – Page 2. Welcome aboard, Chris Leeds (Yeadon) August 28, 2006 at 7:03 pm #186797 phil59Participant thanks chris much appreciated August 28, 2006 at 7:11 pm #186798 phil59Participant chris ,all that tells me is its the pressure switch but ive changed it for 4 diff ones still same?? August 28, 2006 at 7:28 pm #186799 Penguin45Participant Re: indesit w143 10 flashes Great, isn’t it……….. Not really a magic bullet solution. What’s it actually doing? Does it get started filling at all? Other suspects ; Wiring, air hose and chamber, edge connector to board, bord itself 🙁 . Chris. August 28, 2006 at 11:16 pm #186800 phil59Participant on start up usual light flash door lock activates then nothing for a few secs then it throws out of prog with 10 flashes and continually pumps August 29, 2006 at 12:33 am #186801 Penguin45Participant Re: indesit w143 10 flashes Sounds like the flood protection is operating – if you’ve swapped out the p/sw (new?), so wiring or board most likely candidate. Chris. August 29, 2006 at 10:48 am #186802 DDSDDSParticipant Re: indesit w143 10 flashes DEFINATLY CHECK the board for damage clean it up and make sure wires all nice and tight to it August 29, 2006 at 8:19 pm #186803 phil59Participant thanks guys for your help i think its the board ill change it tomozz August 29, 2006 at 8:29 pm #186804 funkyboogyParticipant Re: indesit w143 10 flashes take a spare motor with you as well… can cause this prob cheers ally August 29, 2006 at 10:33 pm #186805 phil59Participant cheers ally will do thanks phil September 2, 2006 at 5:58 pm #186806 phil59Participant wozzzzz the board changed now ok thanks guys phil Author Posts Viewing 12 posts - 1 through 12 (of 12 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
