Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit W143 dial clicks round – light flashes
- This topic has 6 replies, 2 voices, and was last updated 14 years, 1 month ago by
Bigchap.
February 11, 2012 at 12:10 am #67838
Bigchap
ParticipantHi, this machine stopped spinning at full speed for a few weeks and now when you switch on to run say program 4, it sits and does noting for a few minutes then the dial clicks right round. Other times it will take in some water then click round. the light flickers a few times but hard to count and i don’t think it is consistent each time. If I set it to drain it will do that but drum never turns.
Tried replacing the timer as it was easy to get at, and the machine worked fine for one wash, drum turned properly etc and it span, then next time it was back to the same random behaviour. Any ideas?
February 11, 2012 at 12:39 pm #368744iadom
ModeratorRe: Indesit W143 dial clicks round – light flashes
When the timer starts to click round you need to count the number of times the mains/doorlock light flashes, it will flash a set number of times and then pause and repaeat.
February 13, 2012 at 2:25 pm #368745Bigchap
ParticipantRe: Indesit W143 dial clicks round – light flashes
thanks, I tried this again yesterday, but light does not flash now. It stays solid while the timer is clicking round and when finished. It seems that every time i switch on the machine i get a different response. sometimes just the clicking, occasionaly some water pumps into the machine then nothing after that. Other times nothing happens at all. Seems to me that the machine is totaly scrambled so might be better to cut my losses and buy a new one.
February 13, 2012 at 2:35 pm #368746iadom
It might be worth taking the mains plug out and checking the motor carbon brushes first. 😉
February 16, 2012 at 8:46 pm #368747Bigchap
Hi, i took your advice and removed the carbon brushes. they look pretty worn – online around 3-5 mm left on them so I need to order a set. Can you advise the correct ones?
Indesit W143
Motor label says…
Indesco
2040M2 1400
Washing 4.0 W85
Spin 2.0 W320
COD 16001146.02
TA291003MThanks again!
February 16, 2012 at 10:28 pm #368748iadom
Loads of different brushes and motors used on Indesit machines.
Have a look HERE
You possibly need the first or second ones down in that list, pictures might help you identify correct ones.
February 19, 2012 at 12:00 am #368749Bigchap
Hi, I replaced the brushes and the washine machine is now running like a dream. Thanks for all of your help. Great service from your parts department and superb advice.
