Indesit W143 problem?
  • #25685
    Morrisey
    My washing machine has been playing up for weeks now; sometimes it works with a cold wash, but never with a hot one. With the dial clicking round indicating a problem, the LED flash count is 7. Any ideas as to what type of fault this is? I can’t find any other posts regarding this code.
    #207053
    Re: Indesit W143 problem?
    It’s a heater relay problem, that means the main board is at fault (as the relay is on the main board). Ultimately it will need a new module board, the heater checking (insulation breakdown etc) and possibly the Pressure switch for good measure? 😥
    #207054
    Morrisey
    Judging from other posts, the solution described by Martin seems to address fault code 8 -Is this the same as fault code 7?
    If so, could I buy a new relay instead of a whole board?
    #207055
    franz
    Fault code 7 is an open circuit heater – check with meter – plug out first
    #207056
    Morrisey
    Cheers franz – it was indeed an open circuit with the heater element 😀
    …you’ve got the misses off my back at last 😉
