Indesit W143S Door Seal
  • #49900
    pegasusk7
    I’ve got a W143S needing a door seal fitting which has the wire and hook type clamp band on to the tub. What sort of a job is this to do? Can the band be changed for a sprung type?
    Cheers,
    Phil
    #302684
    gandh1
    Re: Indesit W143S Door Seal
    easy-peasy ive not ever needed to change anything!
    (except the gasket of course)
    #302685
    wilf
    well I’ve never found it easy!!!!!!!!!!!!!!!!!!!
    wilf
    p.s. the two boots are different sizes and are not interchangeable I’ve tried
    #302686
    pegasusk7
    Wish I’d seen your response before I went out this afternoon, Wilf! I’m definitely with you on this, pig of a job!! Not one I’ll be taking on again!
    Phil
    #302687
    A real PITA to fit, very long nosed, bent pliers are helpful.
    #302688
    bubs
    Some of the Merloni guys use a spring but this seal just lips on, it could come off again.
    I use washing-up liquid on the outside of the seal only where the band fits. Then tie the band with a small cable tie to hold, then use a bent set of pliers. Was swearing on the first one though.
    Had a Servis seal i could not fit at all a few weeks ago, it was the correct part number but had to be stretched overnight to fit.
    Graeme
    #302689
    twinspark
    YEP PIG OF A JOB I USE BENT ENDED LONG NOSE PLIERS AND STILL GET DEAD HAND HALF WAY THROUGH 😕
    #302690
    goosegreen
    I use a pair of 11in long nosed pliers with the tips ground down a tad, A liberal coating of WD40 around the grove and position the joint at about the 2 30 position. Works well with the zipper and the hook and eye type.
    #302691
    bruce118
    there is a tool to fit these,I worked for Hotpoint and have one. They are a modified pair of electricians pliers with 2 pillers welded@ 90deg at ends which hook in to holes in band. They always worked well for me.
    #302692
    bruce118 wrote:there is a tool to fit these,I worked for Hotpoint and have one. They are a modified pair of electricians pliers with 2 pillers welded@ 90deg at ends which hook in to holes in band. They always worked well for me.
    Any idea what the part number is for a pair?
    #302693
    Simon46
    B&Q do a 90 degree pair of pliers. Bought them did the trick on a integrated indesit washer dryer.
    S.
    #302694
    Pigpen4
    I did one this afternoon on a WE12.
    I unhooked the top right tub spring, so that the tub dropped a bit for me – I was then able to use a normal pair of long-nosed pliers to undo and redo the spring clip without too much trouble.
    Don’t forget to re-attach the pressure switch to its hose, though, which comes adrift as the tub drops if you don’t disconnect it first!
    #302695
    washtronics
    changed loads of these seals on various indesit machines, just use a 3.5mm cable tie in the two rings of the clamp and pull tight-never leak, never had a problem 😆
