completly deed,
getting 240 in, susspect pcb, checked all the usual
any-body came across this with this model,
any ideas on part no,s
for pcb , eeprom,
cheers ally
funkyboogy wrote:any-body came across this with this model
Your joking? The modules fail all the while together with the stepper timer unit. There are 2 different modules dependent on serial number. EMW are the best source of replacements and further advice. The parts they supply are guaranteed, the parts from Indesit aren’t 😉
Thats probably why its dead! Try bypassing the s/w to confirm. If its the module with IDC connectors on CND/C/B. The interlock goes to pads 4 & 7 on module e/conn CNF probably the driver triac Q5 (MAC97A8) has blown (or possibly a track). If its the earlier module then its still CNF but not sure which triac. Its not too hard to stick another one in if you have a scrap board for a triac source. Its always worth a try!
If it does restore the neutral then don’t forget to change the interlock before you try it.
