indesit W161
  • #17936
    geuzer
    Indesit W161 when out on a programme will fill with water and instead of slowly turn the clothes it goes into a spin and then the dial just clicks round / any ideas anyone
    #177103
    gegsy
    Re: indesit W161
    Module, tacho on motor fault or wiring to motor damage.
    geuzer
    Re: indesit W161
    gegsy wrote:Module, tacho on motor fault or wiring to motor damage.
    Greg 😆 🙄 what do i do then , where is module located , do i change the motor ?
    #177105
    gegsy
    Re: indesit W161
    Check the wiring form module to motor plug for continuity.
    Check the rear of the motor (opp motor shaft) to see if the small tacho unit is loose or hanging off.
    All these can be done with the power off :plug:
    Any further faulting would best sorted or confirmed by an engineer from the link below.
    Re: indesit W161
    Also count the number of flashes on the mains neon when the knob starts to click round, it should click a set number then pause, then repeat this ubtil you stop it.
    The number of flashes is an error code.
