Indesit W161 UK Bearing change
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit W161 UK Bearing change
Viewing 7 posts - 16 through 22 (of 22 total)
  • #132010
    jimbo2207
    Re: Indesit W161 UK Bearing change
    always blowtorch the pully bolt, saves on torx bits, I agree the halfords ones are best, I’ve come across the small tears in the backplate, clear sealant sorts them out. And make sure you tigten the 8 torx screws very tight, in the machine with the cast iron spider, the spider acts as the rear (top) counterweight.
    #132011
    jimbo2207
    Sorry just to mention. Get some wine bottle corks (the plastic ones are best, cut them into 1 cm slices (widthways), before you start unscrewing the spider, stick the slices on the inside of the back panel screw holes, you know, where those jagged bits of metal have been left by our italian cousins. It saves numerous cuts, I keep a supply of them in my toolbox.
    #132012
    this is beast of a job got 4 stiches in my hand after torx bit broke
    have now bought halfords bit and had no probs so far but am more careful now as to were my hand goes if i slip
    as a cost save and time you can knock out the torx bits from the halfords sockets and replace them have had to as i keep braking the torx30 on the hotpoint wma spiders
    #132013
    I was going to suggest the Snap-On torx bits but it looks like they don’t do the T30 on its own:
    http://buy1.snapon.com/catalog/tools.as … 8&store=uk
    #132014
    @ phildom
    had a talk with a snapon rep he said they all snap and he has to replace them all the time so it seems that this is a failing of the system or more likely the bolt should have a bigger sized torx socket to stop breakage
    #132015
    Simon46
    Just an idea anybody tried an impact driver?
    S.
    #132016
    I’ve used a stout centre punch to get them started before now – that big head means you can deliver some reasonable torque. Mind you, I replace the bolt with a large washer, small washer and a lock washer and a proper 8.8 tensile bolt with a hex head. Let’s face it, it’s Indesit/Ariston, so we’ll be back to do them again in two years time, so make it easy on yourself for next time.
