I’m having a small issue with an Indesit W855G not filling.
Hoses checked, water flowing ok and good pressure.
Inlet valves swapped out brand new
Will spin and pump out when filled manually through the drawer.
What would be preventing the inlet valves from opening?
I see (multimeter) continuity to the pressure switch from the inlet valves.
Do pressure switches give up?
Is there a simple test to verify it’s operation?
Pressure Switch:(from diagram on front of switch)
terminal 21 normally closed to terminal 22 – continuity
term21 normally open to term23 & 24 – continuity
term 11 normally closed to term12 – continuity
term11 normally open term13 & 14 – continuity
I would expect there to be a break in the normally open switch, but maybe i’m wrong. Is this indicative of a faulty pressure switch?
Any ideas/help would be greatly appreciated.
