Indesit W93
Viewing 15 posts - 1 through 15 (of 28 total)
  • #9620
    My washing machine appears to be having a blonde moment! It fills a little, on any setting, turns over slowly and then the programmer just clicks around aimlessly and nothing further happens. It sems locked in some sort of loop! Any suggestions please.
    #134889
    Re: Indesit W93
    The power lamp will flashing in a rhythmical manner, ie 1234 pause, repeat. Count the flashes and report back please.
    Re: Indesit W93
    Thanks for getting back so quickly. The lamp flashes 8 times as it pumps the small amount of water out. The programmer has also reached the end by then.
    #134891
    Re: Indesit W93
    The ‘blond moment’ in this case is a likely Heater and/or Main Circuit Board fault 🙁
    #134892
    Re: Indesit W93
    Thank you very muck for your time, I appreciate it. I shall test the heater for Ohms etc, but is therea way of testing the board please.
    Giles
    #134893
    Re: Indesit W93
    Anonymous wrote:but is therea way of testing the board please
    Not really apart from ‘visual inspection’ it’s a case of plugging a new board in to see if it works….Indesit engineers call the technique “Plug ‘n pray!”
    #134894
    Re: Indesit W93
    Thanks for that. What’s the cost of a new board and where can I get one please?
    #134895
    Re: Indesit W93
    Most of these boards are c.£80 and the dreaded VAT – if you could post the full model designation (ie W93UK) or even better, the serial number, we can tell you exactly.
    Re: Indesit W93
    Well I’ve tested the heater and it checks out at about 20 ohms with my “valve powered” tester, but that is the same as 3 other spares I have so I am assuming that the heater is O.K.
    Now the BRAIN? I’ve had the circuit board out of its plastic box and it all looks fine with no signs of dry joints or smell of overheating. It must however be duff bucause after all the messing, cleaning of contacts and reconnecting etc. the symptoms are still the same.
    BRAIN box number is COD.215006692.06 from a washer W93UK IPX4 LB2000C Serial No 207171712.
    Whats the damage for a new one please chaps?
    #134897
    Re: Indesit W93
    Module is part number C00080981. Typically, being Sunday I can’t find a price for it 🙄 . Dave Conway will be able to advise you later no doubt.
    The module is supplied without the eeprom (small processor), so you have to transfer that across.
    Bear in mind that no spares supplier will ever take back an electronic board under any circumstance, so be absolutely certain of your diagnosis……..
    Re: Indesit W93
    Any further with the price yet? By the way the EEPROM is soldered in, big chip, what a b*##er.
    #134899
    Re: Indesit W93
    Looks like DC’s missed this one – I’ll remind him.
    The eeprom is the little one BTW, now the yarking great big one.
    Dave_Conway
    Re: Indesit W93
    I did miss it sorry, but I can’t check until the morning now.
    I relied on a distributor the other night for a price for a motor and it seems I overquoted.
    I’ll check the Merloni info in the morning for you 😀
    #134901
    Dave_Conway
    Re: Indesit W93
    Hmm.
    The plot thickens. Merloni’s disk comes up with part number C00093157 after serial number 20408….
    Price is £77.15 inc VAT and delivery.
    An email to spares@ukwhitegoods.co.uk if required please 😀
    #134902
    Re: Indesit W93
    Dave,
    Is this really the best price? My rather battered and torn Hotpoint is still on the go, since trying to repair the bollox new one. Is this the the way things are going? My best fix-it or bust will cost me £77 and it may not be the bit?
    I love all the effort you guys put in to this superb web site, but modern technology really sux. I fix £35 million aircraft and feel helples at a poxy washing machine. My instinct is to stick with my Hotpoint. You know the one I mean, brushes every two years and a set of bearings every three! Oh, and a new door seal to make the wife happy!
    Sorry, but isn’t it true?
    Giles
