indesit wa 155 still not sorted
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries indesit wa 155 still not sorted
  • #46189
    delta01
    wa155 no spin
    it just ramps up a little then slows down again and repeats , no sign of brush problems ie com looks clean, it empties fine , no blockages on presure system etc no fault code flashes
    tried pressure switch
    tried control board from emw still no joy
    i have a spare motor that looks the same but with fine type belt pully, same motor plug type is it likley to be compatable ?
    i dont like to be defeated
    #288486
    suedehead1
    Re: indesit wa 155 still not sorted
    stick i on and give it a try find a belt that fits it, check the wires in the plug go to the same parts of the motor.
    #288487
    whitevanman
    check the motor plug last two are tacho use amp tags if havnt got spare
    plug.
    It may look okay but check under the mtr plug cover.
    Wvm
    #288488
    delta01
    thanks guys will try
