Indesit WA155 w/m
  • #32524
    mike412
    Hi folks.
    Is door seal fitting on this machine “straightforward”, or is there anything I should know?. I seem to remember working on one similar model number to this which was a right PITA.
    Thanks in anticipation,
    Regards, Mike.
    #235449
    helo_75
    if your lucky, itll have a spring band, which makes it a hell of a lot easier
    if its one of them hook things, tilt the machine back, put the hook at the bottom, and use a pair of pointed nose pliers… works for me
    #235450
    mike412
    Re: Indesit WA155 w/m
    Thanks for your prompt reply Helo, will give it a look tomorrow.
    Cheers,
    Mike.
    #235451
    The Zanussi spring band is a perfect replacement. 😉
    jim.
