Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit washer/dryer 6125-w ,
- This topic has 14 replies, 4 voices, and was last updated 13 years, 1 month ago by
D1xxx.
February 9, 2013 at 8:21 pm #74058
D1xxx
ParticipantHi all
I have just brought this machine and the washer part is great but when I put the dryer on it smells like burning rubber, its so bad it hurts my eyes , only had it a week so thought I would check if it is a newness thing and will eventually go? any help would be great, I do have warranty if need to call out engineerFebruary 9, 2013 at 8:40 pm #389793DrDill
ParticipantRe: Indesit washer/dryer 6125-w ,
Switch off, unplug and phone the engineer. Newness dosnt cause this
Sent from my iPhone
http://www.kitchenkitsw.comFebruary 9, 2013 at 8:47 pm #389794D1xxx
ok thanks so angry you would think a brand new machine would work properly if I had read the reviews before I wouldnt touch indesit :/
February 9, 2013 at 8:55 pm #389795DrDill
You did take the transit brackets out?
Sent from my iPhone
http://www.kitchenkitsw.comFebruary 9, 2013 at 8:58 pm #389796D1xxx
the 4 sort of bolt things on the back that hold the drum in place for transit?? yes took them out
February 9, 2013 at 9:01 pm #389797Martin
Hilary has the exact same issue top of page 4….. 🙁
February 9, 2013 at 9:07 pm #389798DrDill
Best get the engineer out,
Sent from my iPhone
http://www.kitchenkitsw.comFebruary 9, 2013 at 9:09 pm #389799D1xxx
thanks guys , I did read to do a service wash at 90 with detergent but no laundry do you think this would help ?
February 9, 2013 at 9:11 pm #389800DrDill
I dont think it would at all.
Sent from my iPhone
http://www.kitchenkitsw.comFebruary 9, 2013 at 9:11 pm #389801Martin
Nope!….besides too late now if you haven’t.
February 9, 2013 at 11:38 pm #389802madangler1
Tbh I have seen this a few times its quite common. The door seal and tank absolutely stinks when its on a dry sometimes on a new machine. One woman said it made her physically sick and made here eyes sting.
If you feel its not safe I would get an engineer to check it but id bet they won’t find a problem, It normally goes after a few uses.
1st thing is YES do the 90 wash. This there for a reason to relax the seal and help to settle everything in. In fact do a couple as it help absorb the smell as well.
Then I’d stick it on a long dry program with the windows open and let it burn off all the chemicals from the plastic tank and seal.
It should fade away after a few uses, It’s just the chemicals from the manufacturing process and when the tank and seal heat up its released into the air.
It’s seems to be getting more common tbh. Not sure if its the type of rubber now used in the seals or the plastic in the tank.
Worst case if you do call them get them to swap the seal it can help.
February 10, 2013 at 7:44 am #389803DrDill
And if its not this? Will you be putting yourself up for sorting any damage caused.
Play it safe and get the machine checked
Sent from my iPhone
http://www.kitchenkitsw.comFebruary 10, 2013 at 10:41 am #389804madangler1
I did not say don’t have it checked, what I said was Iv seen it a few times before.
Get an engineer out and have it checked but id expect they won’t find anything.
They have also recently added a high temp silicone to the drier box around NTC to stop hot air getting passed it help prevent the F13 so this may also be smelling.
Id also add that I have found some people seem to be more sensitive to it than other as on the ones I went to for it although I could smell it i was not affected by it or found it anywhere near as bad as the customer did.
One one the lady could not even enter the kitchen where as I could notice it but its did not bother me.
As I said your concerned get them out,, ask them to change the seal if they can’t find anything as Iv always believed this was the main source of it.February 10, 2013 at 11:04 am #389805Martin
This is indeed a fascinating insight into the wonders of the Indesit washer-dryer. It just falls short of a true indictment without further eye witness accounting by the unfortunate owner. I do hope D1xxx will return and tell us the detailed outcome of the engineers visit in due course? 😀
February 10, 2013 at 6:28 pm #389806D1xxx
hi been out all day but tomorrow I will put it on a 90 degree service wash ans see, if that fails I will call out engineer, thanks for your help guys and yes I will report back as to help other folk xx
