I was testing my third machine in a wash & dry cycle. It has a split door seal and leaks water but i wanted to make sure the balance of plant was functional before investing in a new door seal and offering it for sale.
The machine was into the rinse cycle when it stopped and gave a 15 flash code. I tried searching for this and was unable to find a match. Advice?
Equator Model EZ3612CEE.
Thanks in advance.
I found a post under Ariston. I will check the pump housing (pump was working but machine stopped during a rinse cycle with water in the drum) and the heater relay. With a bad door seal any expensive parts required will compel me to part this machine out or junk it.
Check that the dryer element is connected, the inline thermal fuse has continuity through it, and that there is resistance through the dryer element. Not quite sure what you should get as you’re on 110v.
If all that checks out, the pcb in the bottom is probably faulty.
