indesit washer dryer iwde126
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries indesit washer dryer iwde126
  • #78841
    lyndy
    indesit washer dryer not finishing the drying program.everything is clean and it is heating up.it flashes from the 1st 2nd and 4th led when it faults.sn 11118231 80624630085
    #407088
    Re: indesit washer dryer iwde126
    Same as these AFAIK.
    widl codes – light flashing from left to right are numbers 1-4
    f01 light 4, motor triac
    f02 light 3 motor, jammed/ tacho
    f03 lights 3&4 Ntc fault
    f04 light 2. pressure sw stuck on empty
    f05 lights 2&4, pressure sw stuck on full
    f06 lights 2&3, N/A?
    f07 lights 2&3&4 heater relay or O/C element.
    f08 light 1. heater relay
    f09 lights 1&4 eprom/setup error
    f10 lights 1&3, pressure switch not sensing
    f11 lights 1&3&4, pump/draining error
    f12 lights 1&2, communication error
    f13 lights 1&2&4, dryer ntc/ fan motor
    f14 lights 1&2&3, dryer heater
    f15 lights 1&2&3&4, dryer heater relay
    f16 N/A
    f17 light 4, door lock
    f18 light 3 comms error (3 phase motor) power board
    f1 and f17 share the same light
    F13.
    – Check efficiency of contacts on connector J011 (commutator) or
    J14 (three-phase) on PCB;
    – Check NTC impedance value on wiring connectors J011
    (commutator) or J14 (three-phase) between pin 1 and pin 2.
    The impedance value at ambient temperature (20°C) must be
    approximately 20 KOhm;
    – If measurement is incorrect check NTC wiring;
    – Check the same parameter directly on the NTC (20 KOhm);
    – Renew NTC;
    – Renew PCB.
