Indesit Washer/dryer Mod WIDL 126
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit Washer/dryer Mod WIDL 126
  • #36191
    Ashby
    Hi Everyone, Have got this Indesit washer/Dryer. It will fill start to tumble then stop and the 4th light along from the left plus the door lock led will flash. it does the same whatever program i set it on.I have checked the motor and module connections and all appears to be fine. Any suggestions will be most appreciated. Many Thanks.
    Ashby :rolls:
    #249946
    helo_75
    it is an f01 fault – which tends to be a motor triac fault
    bard nd eprom req’d im afraid
    #249947
    Ashby
    Re: Indesit Washer/dryer Mod WIDL 126
    Hi, thanks for your reply. If it’s a motor triac fault, should i be changing the motor as well as the board?
    Ashby
    #249948
    helo_75
    not always, no
    test it, megger it. it might be ok
    #249949
    I would go through a full spin with the repaired/renewed board and check for bad sparking at the brushes. No point fitting a new motor unless it needs one.
    #249950
    Ashby
    Hi, I’ve just replaced the board on this machine and still getting the same fault? F01
    any suggestions?
    Ashby
    #249951
    helo_75
    hmmm
    wiring/harness damaged/broken or faulty motor
