Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit Washer Dryer not drying
- This topic has 9 replies, 4 voices, and was last updated 14 years, 4 months ago by
davecross.
December 6, 2011 at 6:20 am #66690
davecross
ParticipantI have an Indesit Washer / Dryer PWD8148S
Just over 1 year old and has developed a fault just after guarantee ran out.
No heat on dry cycle.
TOC is operative – it has 30ohms across it. If I remove it a Fault code appears after about 10 mins.
Fan comes on and off and I can here the fan rotating. I also see 240V across the terminals when fan on.
Wiring to heater and fan looks good. I have checked connectors.
No 240V at heating terminals at any time during drying cycle.
Condenser reservoir is not blocked.
I am now stuck. Any ideas. It sounds to me like an output triac feeding the heater has gone.
Heater terminals have about 35ohms across them.December 6, 2011 at 8:32 am #364889Martin
ParticipantRe: Indesit Washer Dryer not drying
davecross wrote:TOC is operative – it has 30ohms across it.
It’s not a TOC by the way but a thermistor (a.k.a an NTC) the resitance value of it measured in kOhms not ohms. Try replacing that first, if not the main control PCB is the next suspect. 🙁
December 6, 2011 at 6:29 pm #364890davecross
Thanks Martin.
Do I read from your reply that this model doesn’t have a TOC?
Do you know what resistance should I expect from the NTC Thermistor when cold say at room temp 20C?
Are we talking of the same unit. The one I removed to produce the fault is the one with 2 thin blue wires at the front of the machine near to the blown air inlet to the drum.
What resistance value would I have to put across the 2 terminals to force the heater on to test whether the thermistor is at fault?December 6, 2011 at 8:05 pm #364891Martin
Yep its an NTC for sure though I dont know what the room temp reading would be but I’m guessing something around 12kohms?
December 6, 2011 at 8:09 pm #364892BobHope
it 20koms at 20c.
Bob.
December 6, 2011 at 10:00 pm #364893davecross
Thanks Martin and Bob.
It is reading about 30 ohms so I guess the controller thinks it is too hot as it’s an NTC which fits the symptoms.So what I’ll do is temporarily wire a 47k across the terminals and see if heater comes on during the cycle.
If it does I’ll replace the thermostat.Of course I’ll switch it off immediately once I know it’s working as I don’t want it to overheat.
I’ll let you know what the outcome is.
December 7, 2011 at 12:14 am #364894Firestarter
ParticipantIndesit Washer Dryer not drying
Take a careful look at the thin blue Ntc wires where they are cable tied to the cabinet at the top. I have found a few have broken by the tie. Give then a little tug – they may well be held in place by the plastic only with all the copper conductors snapped inside.
December 7, 2011 at 4:35 pm #364895BobHope
if the wire is open circuit it gives an f13 fault code.
Bob.
December 11, 2011 at 3:37 pm #364896davecross
The wires are not snapped. If I open circuit them I get the F13 fault code after about 10 mins.
Upon removing the NTC thermistor the contacts read 19ohms so I’ll get a replacement.
I’ll let you know if this fixes it.
I’ve ordered C00083915 Indesit NTC Thermistor. Even though my model is not listed it looks like the one I need.December 16, 2011 at 4:54 pm #364897davecross
NTC Thermistor arrived yesterday. It reads 20k at room temperature as expected.
Fitted and now dryer works.
Thanks everyone for your time and effort. 😀 -
