We have got one of the above machines, its driving me mad! i keep getting an F-08 fault and more recently an F-15 fault, it takes me about 10 tries to get it going, but then it will wash fine for the full program, then when i go to use it again i get the same problems! anyone any ideas what might be the problem?
F08 is a heater relay fault, F15 is a dryer relay fault, could just be poor connections which are very common on these low end machines or a fault on the main PCB itself.
If you use the search facility and type in “eight AND flashes AND Indesit” it will give you some idea of the problems you are faced with. :rolls:
