indesit washer plastic drum paddel
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries indesit washer plastic drum paddel
  • #101738
    adv
    hi guys the metal tab is broken off that lock it in place , what can i do to fix it . am thinking super glue :rolleyes:. anyone else got a better idea ?
    #485875
    clockworkone
    Quite common problem now. I use a long cable tie. Put tie on loosely through holes under paddle and holes in paddle. Fit paddle and then tighten tie. Cut tie and I just run a file to to where i cut tie. Don’t think superglue would last too long.
    #485876
    adv
    clockworkone wrote:Quite common problem now. I use a long cable tie. Put tie on loosely through holes under paddle and holes in paddle. Fit paddle and then tighten tie. Cut tie and I just run a file to to where i cut tie. Don’t think superglue would last too long.
    ok thanks pal 😉
    #485877
    adv
    i decided to drill a small hole and put a self taper screw in . hope it does the trick :rolleyes:
