indesit washing machine pulley working loose
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries indesit washing machine pulley working loose
  • #66088
    fasetester
    does any one have bother with machine pulley bolt working loose the machine is a indesit mod wib 101 the custmor said it has happened before is their any thing you can do that does not involve a box of matches lol :)thanks fasetester
    #363010
    cab
    Re: indesit washing machine pulley working loose
    LOCTITE
    #363011
    fasetester
    cab wrote:LOCTITE
    thanks for your reply cab the tread sealer type you use for general bolts that you get in car care
    #363012
    cab
    yep, is it made in china by anychance? like the one I did today, it was one of those currys essencial thingys
    #363013
    chippo
    You might need to replace the pulley if there is movement on the shaft.
    #363014
    fasetester
    cab wrote:yep, is it made in china by anychance? like the one I did today, it was one of those currys essencial thingys
    it has come loose before when machine was not long new so when the bolt is tightened if their is still play need new pulley. thanks cab
    #363015
    fasetester
    chippo wrote:You might need to replace the pulley if there is movement on the shaft.
    thanks chippo for your reply fasetester
