Indesit Washing Machine W103
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit Washing Machine W103
  • #6843
    rjrichmond
    Can anyone tell me what the problem is with my washing machine? When I turn it on it starts to fill then it stops after a few seconds and from then on the programme dial starts clicking round constantly….and the power light goes on and off at the same time!
    #119869
    Dave_Conway
    Re: Indesit Washing Machine W103
    The power light should flash in a sequence then pause.
    i.e. 3 flashes – pause – 3 flashes.
    If you can count the number of flashes it may give us a clue, although sometimes this is not conclusive, normally you will need an engineer to check it out for. What you are desribing is the machine’s control unit detecting an error, it then aborts the programme.
    #119870
    rjrichmond
    It seems to do 8 single flashes although when I first turned it on it did a few single flashes then 3 in quick succession.
    #119871
    Dave_Conway
    If it’s either 8 or 3 it is related to water heating and/or water heat control.
    Best bet is ask an engineer to have a look at it for you, if the main control unit has failed, these can now be repaired saving some of the cost of the £60-£80 for a replacement.
    Let us know your postcode, someone should be able to assist with this.
    PS. Your other post deleted as it relates to the same machine i assume.
    #119872
    rjrichmond
    Dave_Conway wrote:If it’s either 8 or 3 it is related to water heating and/or water heat control.
    Thanks. Postcode is AL4. I only paid £60 for it second hand (obviously now know I was conned as they told me it was working!)
    #119873
    rjrichmond wrote:I only paid £60 for it second hand (obviously now know I was conned as they told me it was working!)
    To be honest unless you can get a refund from whoever sold it you, at this stage it’s best not to get too involved. It will be expensive to fix without doubt 🙁
    rjrichmond
    Will it cost more than the £60 we paid for it, do you think?
    #119875
    and much more besides I’m afraid 🙁
