Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › indesit washing machine Wia111uk on off light flashing
- This topic has 8 replies, 5 voices, and was last updated 17 years, 7 months ago by
CHRIS24.
September 8, 2008 at 7:17 am #39305
CHRIS24
ParticipantAlthough the machine is working fine, when the macine is turned off on the dial the on off light flashes continually
Can anyone help please
September 8, 2008 at 1:40 pm #261976stripey
ParticipantRe: indesit washing machine Wia111uk on off light flashing
This is normal it is telling you that it has finished the prog and is ready to start a new one.
September 8, 2008 at 3:16 pm #261977cessna
If light stays on when you turn the dial to off then it is a module fault.
Quite a common fault on this model.If it’s insured or under guarantee then get it seen to if not and you can live with a flashing light then leave it.
As you say the appliance will still operate normally.September 8, 2008 at 6:19 pm #261978helo_75
Participantlol stripey.. and you work for hotpoint
yep, needs a pcb and eprom… it is common, as cessna says, it simply isnt resetting
September 8, 2008 at 6:21 pm #261979hotpnt
stripey wrote:This is normal it is telling you that it has finished the prog and is ready to start a new one.
no, the light should go off,
as helo says it does need a new module, also beware if continuing to use it as it is a sign that the dial is no longer corresponding to the programme you have chosen, so you may well be selecting a cool wash but the board will run a hot wash, needs fixing really
September 9, 2008 at 8:15 am #261980CHRIS24
Many thanks to all i will switch it off at wall and hope for best as new module approx £100
Chris
September 9, 2008 at 9:22 am #261981stripey
Taken from the user manual.
“When the programe is finished the DOOR LOCK Led will flash to indicate that the appliance door can be opened”
September 9, 2008 at 10:48 am #261982CHRIS24
STRIPEY
Please READ my comments and the other peoples comments the lights continue flashing even when the dial is turned to the off position which they should NOTSeptember 9, 2008 at 8:16 pm #261983helo_75
Participantomg stripey, u really are a goon
u make yourself look more pathetic with every post
do you think the poster would have asked the question, after possibly 2 years if he didnt think there was a problem?
the light WILL NOT flash in the off position, which, funnily enough, is when the machine should be off
