Indesit washing machine WIB101 belt question?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit washing machine WIB101 belt question?
Viewing 15 posts - 16 through 30 (of 35 total)
  • #363116
    Re: Indesit washing machine WIB101 belt question?
    Sounds like a slightly worn pulley, part number C00064527, around £18.00.
    If the belt is now staying on the you should be able to use it until you get a new pulley.
    #363117
    Allsorts
    As iadom said above, if you have the nylon pulley it may need replacing as the center will normally be worn due to the wobbling movement the pulley makes whilst loose…
    The replacement is part number C00064527, normally a metal pulley to correct the problem.
    If you can not get the bolt off with the normal tools then you will need to use a small chisel or similar tool to tap the edge of the bolt to eleviate its grip on the pulley; however, if you do this then you may need to replace the bolt too.
    #363118
    lovely
    Thanks for the replys guy 🙂
    Oh boy, I was hoping not to spend any more money……. its like i have open up a money pit
    I am going to have to save some pennies and raid piggy bank to get the money together 🙁
    I will see if i can use Machine in the meantime
    #363119
    lovely
    Well i got machine going for a while, no more than 10 mins,
    then i heard the belt come off.
    I took off back of machine again and the bolt/screw in centre of pulley had loosened itself again, so i unscrewed took off pulley, there seems to be no wear or tear on either bolt/screw or pulley?
    There is alot of black dust, i assume/hope this is normal?
    #363120
    No, the black dust is a sign of a worn pulley and TBH if you keep using it like this you will end up wearing the drum shaft as well.
    You need to get a new pulley ASAP and use some kind of Loctite locking solution on the threads of the securing nut.
    You can get Loctite ‘thread lock’ from most DIY stores etc.
    #363121
    lovely
    😳 no i wont be using machine again.
    I am aiming to get new pulley sometime next week & will look for Loctite locking solution for threads of securing nut in local DIY store 😀
    thanks iadom
    #363122
    lovely
    😀 Hi,
    i am back with new pulley and belt and new problem.
    i have fitted both and when i turn drum, no more knocking sounds, but, very loud squeaking/squealing? sound and very difficult to turn?
    what do i do now?
    #363123
    Is it difficult to turn with the belt off?
    #363124
    lovely
    yes,
    difficult when belt is on or off.
    #363125
    If it was nice and free without any noise before you fitted the pulley then either you have fitted the wrong pulley or allowed large amounts of loctite to get into the bearings????
    #363126
    lovely
    no loctite used
    the part i ordered i was advised to, from UK whitegoods,
    pulley part C00064527,
    #363127
    Not being able to see it makes it difficult, if you remove the pulley and refit the old one and it spins freely then either the pulley is faulty or is fitted incorrectly.
    What is the full serial number of your machine, does the new pulley look like the old one?
    #363128
    Allsorts
    If it runs freely without the pulley then there is a problem with the pulley.. either fitting or otherwise.. However, if it is still stiff when you remove the pulley then it sounds like the bearings were worn and in the 2 months since the last problem they have seized.
    Although as iadom has said, it is hard to determine without seeing the machine.
    #363129
    lovely
    my old pulley was plastic, the new one is metal?
    different hole opening on both?
    when the old pulley is on no squeaking/squealing noise, just the slight knocking, machine died in august? and have not used it, Bearing have now seized up? not sure that sounds right?
    when i turn the dum buy itself with no pulley, there isn’t any noise, knocking or squealing
    old plastic pulley fits snug and all the way back on part that comes out back of drum, when i put the new pulley and push it all the way back, it sqeaks/squeals when i turn it.
    I have tried it without pushing it all the way on and attach belt it spins with no noise, but belt does not stay on and its doesn’t turn straight.
    #363130
    lovely
    any answers?
