Indesit washing machine WIB101 belt question?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit washing machine WIB101 belt question?
Viewing 5 posts - 31 through 35 (of 35 total)
  • #363131
    Re: Indesit washing machine WIB101 belt question?
    iadom wrote:Not being able to see it makes it difficult.
    What is the full serial number of your machine
    #363132
    lovely
    where will i find the serial number?
    how will it help me?
    #363133
    It will be inside the door or on the back, it may not be much help, the parts diagrams do show an alternative drum set up but it is a tiny picture, very indistinct and with very little extra information.
    The pulley you have is the correct one according to the Indesit parts software, we have nothing else to go on other than that.
    Does the new pulley look ‘flat’ on the inside around the hole for the shaft, no sign of any burrs or rough moulding?
    #363134
    lovely
    seriel number 811136498
    the old plastic pulley has two grooves either side, in hole area,
    the new pulley is smooth in the hole and no grooves, there is what looks like a small amount of rough/jagged bit on outside of hole, that faces outwards,
    but i cant push the new pulley all the way snug like the plastic one sits, so the rough bit hasn’t made contact with anything?
    #363135
    Serial number suggesets you have the correct part, but as mentioned several times, if we cannot see the part we can only guess.
