Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › indesit washingmachine wib101
- This topic has 6 replies, 2 voices, and was last updated 13 years, 1 month ago by
fasetester.
February 27, 2013 at 3:19 pm #74353
fasetester
Participantwashing machine belt shredded got new belt went put it on. had to tighten pulley as was loose how tight should the bolt be on the pully.as far as i know it has come loose before.
tested machine on a spin program ok. just got phone call to say belt came off when machine went to do first wash. any information on what the problum could be. thanks fasetesterFebruary 27, 2013 at 3:24 pm #391129Martin
ParticipantRe: indesit washingmachine wib101
If the pulley has any movement on the shaft at all it is best to fit a new pulley and then Loctite the bolt very tight.
February 27, 2013 at 3:33 pm #391130fasetester
thanks martin for your reply. do i tighten the bolt as tight as it will go. i was afraid of snapping the bolt. when the pulley is turned round should it run even.fasetester
February 27, 2013 at 3:40 pm #391131Martin
Without doubt it should rotate straight and true. Trouble is that when an alloy pulley works loose inevitably it’s inside edges wear. If there is any movement at all on the shaft then no matter how tight the bolt it will work loose very swiftly. I would not hesitate but to put on a new pulley (C00064527).
The belt you fitted was a stretch belt wasn’t it?
March 1, 2013 at 2:30 pm #391132fasetester
thanks for your reply martin. the pulley is a plastic or baklite. there was some play in the pulley.
with the torx bolt you dont think you are getting a lot of torx. when tightening would it not be better with a hexibolt.
or a hexibolt would let you apply to much torx and crack the pulley. would it matter if there is slight movement in the drum.
no noise on spin thanks. fasetester.
March 1, 2013 at 3:35 pm #391133Martin
You never use a question mark so I always have to read your post twice to find the missing question. Can you use one of these is future please?
The Torx bolt will be fine but you must use Loctite on the thread first. 😉
March 4, 2013 at 4:41 pm #391134fasetester
ok martin thanks for the reply pat
