Re: Indesit Water Warning?
Right, answered my own question.
Had a service visit & the engineer was a bit baffled after checking a few things on the machine & also his laptop.
He said there was no water circulation within the machine (supply ok). It was just timing out & bringing the water supply lights on.
After consulting his technician he changed the main circulating pump which made no difference.
After consulting his technician again he said he was going to have to order a new air break & turbine plus a water solenoid valve as backup & arrange a further visit.
The second engineer came today & fitted the new air break & turbine, he said the solenoid valve would not be needed, they either work or not. Obviously mine was.
Anyway after fitting said air break/turbine the machine worked perfectly! Everything was much quicker, spray arms kicking in/detergent door opening etc.
