INDESIT WD10
  • #42577
    simonb
    Fault is fill on any position,(although rest of functions seem to be working) im sure its the same old thing merloni board, i did notice when i took a wire of the value that is constant filling the machine appears to work ok, thats only with a test of a few mins,
    will it work with hotvalue switched out, or is it a complete new board
    #274031
    Re: INDESIT WD10
    had a servis doing this before christmas valve had 110 volts on it constantly
    fix trace wire back to board and replaced triac works ok now no problems since
    hope this helps
