Indesit WD10 error code 15
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WD10 error code 15
  • #9118
    geegee
    Hi, can anyone suggest anything to check on an Indesit WD10 UK that’s giving me an error code 15? Other posts I’ve found say that code 15 means problems with the dryer heater, but that seems to be one of the things that is working… The problems come in wash and rinse programmes, where the machine fills but then very soon afterwards pumps the water out again and leaves the programme selector clicking round indefinitely. Spin cycles seem to be OK, and there don’t seem to be any blockages in the pump (looking in the chamber at the front rh side of the machine), or the drain hose. Thanks very much in advance
    GG
    #132436
    Dave_Conway
    Re: Indesit WD10 error code 15
    Error 15 is indeed related to the dryer heater, but as you may have also read, fault codes are quite often incorrect and sometimes misleading.
    It sounds like this could be pressure switch related to me, please pull the plug before checking anything though :zap:
    #132437
    geegee
    Thanks very much for the suggestion, Dave… I guess if I have to ask what a pressure switch is I should really be phoning an engineer…
    #132438
    Dave_Conway
    probably best in that case, try here:
    Repairs@
    #132439
    lowie
    Hi, we have the same model and this has been a niggling problem since about a year after we purchased the machine. We have had 1 new module fitted but we got the same error just before xmas had the engineer out and he couldn’t find a problem, ran machine agian ok for a few cycles but has faulted again with 15 flashes, so it could be that you need a new module too 😀
