Indesit WD10 – sticking timer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit WD10 – sticking timer
  • #24109
    richy
    Programme selects ok the drum turns a couple of times and the heater comes on. The heater then switches off after a couple of minutes and the timer sticks on programme permanently – no flashing lights or motor action. Checked heater, motor, pressure switch and inlet solenoids. help?
    #200717
    Re: Indesit WD10 – sticking timer
    Hi Richy,
    Looks like no-one’s got the answer….. Sorry. If everything else checks out, gotta be the board/eeprom really.
    Welcome aboard, BTW.
    Alan1476
    HI there
    Check then connections on the main pcb which go to the pressure switch make sure that ther isnt a bad contact there. Also make sure that the appliance isnt calling for water via a faulty valve. Or the machine isnt trying to empty Via a blocked pump. Failing all that you are probibly looking at a faulty module.
    Good Luck
    Alan
    #200719
    Check motor brush or try to change the motor itself. I have had many of that mistakes (rotor impedance is out of range from electric point of view). But also you can try another memory (less probably will resolve the problem) or you can rewrite her.
