my washer/dryer will not stop water filling as long as the dryer switch is on (any position). As soon as the switch is turned off, the water immediately stops water filling. Any ideas?
It does this even during the wash cycle, as long as the drier timer is on. In the meantime, I have disconnected the wires going to the drier switch and everything else appears to be normal. Where can I get a replacement module?
If you post up the serial number I can check the module price etc for you, but I would discount all other possibilities first as i’m only making an assumption on the information.
You won’t get much change from £100 for the PCB and if it doesn’t solve the problem ….
