Re: Indesit WD11 – something between drum & housing?
Garbetklb wrote:
How do I get to between drum & housing to remove the offending item?
You don’t, inner and outer drum are a sealed assembly costing just under £125.00 for the part. 😥 It is also quite common for coins to slice holes in these ultra thin drums, suggest extreme care in future. The later Indesit, Hotpoint & Ariston machines together with several other manufacturers now come with sealed poly drums as well, making any repair such as bearings, drum supports, inner drums etc into a complete drum change every time. When the time comes to change it make sure you investigate just what you are buying the next time.
