i have put a new board in this machine cause it was showing e15 which is dryer relay fault. when i fitted board from ewm it fixed fault but the slave unit just clicks round all the time and it doesnt sound very healthy. the cycle works ok but slave unit continuosly clicks round and no error code is flashing. have checked for all other faults think mit may be slave unit. can any one help??
Probably should have got board from EMW instead of Edinburgh Woollen Mill 😆 .
Still, I’d give Tony a ring if I were you. He’ll have some idea what’s going on with it and will advise for sure.
Mike.
