indesit WD12
  • #19950
    kevinlewis
    It fills via the prewash valve continually as soon as power is switched on. The red light flashes rapidly, too fast to count. The drum rotates both direction whilst filling. When the water level reaches half way up the drum the suds pump kicks in while it continues to fill. Customer says it does actually finish its programme!
    I disconected the heaters and the motor, chcked the pressure stat and pipe. Inspected the PCB. All seems fine.
    Any idea?
    Any
    #185156
    DDSDDS
    Re: indesit WD12
    i think the fault is its an indesit
    but that aside does it flash too fast to count all the way through the cycle? and does itactually heat etc
    i would say p switch or most likely mod fault
    but aint come across it b4
    #185157
    Re: indesit WD12
    99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain a control module failure. Have seen this fault several times.
    Kevin, I have moved this into the Trade Tech forum, best to keep this stuff away from the Public forums. 😉
    #185158
    Tony_EMW
    Re: indesit WD12
    Classic fault on these boards. Fit a new board – all will be ok. We’ve got them in stock inc eprom £34.90+vat Tony 0115 9652118
    #185159
    kevinlewis
    Re: indesit WD12
    Thanks all for the advice. Changed the module, reset it using the imformation included with part and all seems well.
