Indesit WD12
  • #21199
    machineman
    DEAD,feed coming in,on/off switch working ,no lights nothing .checked board for burn outs ,checked selector for arcing on contacts,shorted door switch,nowt ,any suggestions.m
    #189992
    Check if you have after swiching “ON” on main PCB 220Volts-AC(primar of trafo); 12Volts-AC(secondar of trafo); 5 Volts-CC on the near conder to microcontroler and after that I can guide you forward.
    PS. If you are not qualified don’t play with…220Volts
    #189993
    Martin114
    Re: Indesit WD12
    Motor o/c – brushes 💡
    #189994
    Simon46
    Re: Indesit WD12
    Brushes.
    S.
    #189995
    This is also an question: whitout brushes the communication LED (power) doesn’t lid?
    #189996
    Re: Indesit WD12
    The most common cause is the on/off switch as its so vunerably located with little room between it and the dryer ducting!
    #189997
    machineman
    not brushes nor on/off switch.m
    #189998
    MickGeorge
    Re: Indesit WD12
    Silly I know – Door interlock? 🙂
    #189999
    machineman
    shorted door sw out.m
