Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit WD12 error codes?
- This topic has 7 replies, 3 voices, and was last updated 19 years, 11 months ago by
DarthWeasel.
May 7, 2006 at 6:12 pm #17652
DarthWeasel
ParticipantI have an Indesit WD12 which is doing the rotating dial thing.
I’ve switched it off and managed to get the washing (and a load of water) out.
How do I determine which error code it’s displaying?
I’ve set the dial to the dot, turned the machine off and back on again, and the main LED flashes twice, then a number of times rapidly, then back to slower flashes. Is the two flashes the error?
Darth Weasel
May 7, 2006 at 6:27 pm #175625Penguin45
ParticipantRe: Indesit WD12 error codes?
DarthWeasel wrote:I’ve set the dial to the dot, turned the machine off and back on again, and the main LED flashes twice, then a number of times rapidly, then back to slower flashes. Is the two flashes the error?
No, you’ve reset the computer and cancelled the error code. Run the appliance again, when the dial starts clunking round count the pattern of the power light ie, 1234 pause repeat.
THEN cancel it………… 😀
Penguin45.May 7, 2006 at 6:50 pm #175626DarthWeasel
OK, I’ve just set the machine off again on a short wash . . .
May 7, 2006 at 7:29 pm #175627DarthWeasel
Just ran an empty short wash (number 8) and had no problems . . . wierd . . . does this mean I can put the Argos catalogue away?
May 7, 2006 at 7:39 pm #175628Penguin45
See how you go…….
If you’re considering replacement, please use a local independent – you’ll get sound advice on choice and value.
May 8, 2006 at 5:34 pm #175629DarthWeasel
Tried the machine again – the LED is flashing five times. Seems to me it’s not draining . . .
May 8, 2006 at 6:00 pm #175630Dave_Conway
Possibly the pump is blocked then, have you checked the filter ?
F05 is pretty well covered here, if you use the search:
http://www.ukwhitegoods.co.uk/modules.p … ile=search
Then search for “F05” (without the quotes), that should help 😀
May 8, 2006 at 8:43 pm #175631DarthWeasel
Checked the filter(?) at the front of the machine and there was a piece of black cord about 5″ long lurking right at the back. Removed it and everything is fine!
Thanks for your help, you’ve saved me a callout or even a new machine . . .
