Re: Indesit WD12 fault code F04
kidsy wrote:When starting a program, it fills up, the drum rotates 3 or 4 times, then the selector switch startes to rotate and it empties the water.
Well Gavin I would suggest you wait for the engineer to return and rectify the fault to be honest. 🙁
The fault code you observe relates to a water level control problem, but it could also relate to a bad connection with the components that have been replaced? So it’s best to leave well alone! 😉
