indesit wd12 rotating selector two flashes error
Home Forums Public Support Forums Help And Support Washing Machine Help Forum indesit wd12 rotating selector two flashes error
Viewing 15 posts - 1 through 15 (of 15 total)
  • #11136
    hi all
    I have a indesit wd 12 thats about couple of years old, suddenly wont work properly.
    on almost any programme ( use mostly 3 &4 )will start ,then fill, couple of quick tumbles (do seem rather fast )
    THEN immediately drains and selector knob goes round and round,
    it gives TWO FLASHES every now and again
    checked drain, checked pipes in/out, check water level pie and chamber all clear, tried any number of “resets”
    any help much appreciated
    cheers
    john
    #144065
    Re: indesit wd12 rotating selector two flashes error
    Motor problems could cause this or a failure with the Control Module, could be costly to sort 🙁
    #144066
    Martin thanks for such a quick reply,
    is there anything I can check myself first (reasonably ok diy’r) ,perhaps brushes etc, loose connections ..
    cheers
    john
    #144067
    Dave_Conway
    Carefully inspect the motor for anything obvious John, especially the opposite end to the belt 😉
    Power off :zap: of course 😀
    #144068
    Hi there dave and martin,
    with machine unplugged
    have removed and replaced the brushes, the motor is clean, comutator undamaged all wiring looks ok
    have removed and checked the control board no sign of burnt components or tracks,
    checked every other connection and ran the machine again,
    on RINSE fills far too full ( nearly half filled drum ) tried to tumble then went to drain and …of course rotating selector.
    run it again on programme 4 filled to what i guess was normal level then after a couple of tumble ( still too fast ) went to drain…and rotating selector.
    The only thing that appears common is the speed it does these first couple of tumbles it seems far too quick, so is it a motor speed issue ?
    maybe its just me, if I could see something broken I could choose to fix or buy another machine.but faced with a call out and parts bill ( to fix something I cant see is broken ) for nearly the same as a new one makes me very unhappy!!
    so any ideas to soothe my scottish ancestral resistance to spend money would be much appreciated.
    cheers
    john
    #144069
    Dave_Conway
    It’s clearly a motor speed control problem, although that wouldn’t explain the overfilling issue.
    If you are able to test for continuity, check the coil on the opposite end of the motor, if it’s open circuit then that is where the problem lies but I suspect either the PCB is faulty or the motor winding/armature may have a short circuit somewhere.
    Both of those are expensive as Martin indicated earlier, £80-£90 for the PCB (there are two, serial number required) and £110 for the motor.
    It may of course be neither of those, wthout the correct test equipment diagnosis is difficult at best….
    #144070
    Good morning guys
    Thanks for info, have removed motor to test ( machine unplugged )
    I think I am testing what you recommended,
    pin 1& 2 ( brushes ) closed
    pin 3& 4 ( ? ) closed
    pin 5&6 ( 2 reds ) open
    no other combinations make circuit
    Does that make it the motor?
    thanks for your help
    cheers
    john
    #144071
    I don’t have a wiring diagram for this machine but I suspect the 2 red wires you refer to go to the Tacho Coil at the end of the motor?
    If that is the case and they are open circuit? Then that is the fault and a new Motor the only option 🙁
    #144072
    Hi martin,
    thanks for reply,
    The two red are to a component on the end of the motor opposite the pulley end, and they do not make a circuit to themselves or anything else
    does that identify it as “dead motor”
    cheers
    john
    #144073
    john guest wrote:does that identify it as “dead motor”
    A Tacho Coil (on the opposite end to the pulley) should show a reading of approx 150 to 190 ohms, no reading or at least no continuity showing, then it’s got to be a faulty motor 🙁
    Look closely too at the crimped connections on that motor plug as vibration often breaks the copper conductor whilst leaving the PVC sheath intact 💡
    #144074
    Hi Martin,
    thanks for reply,
    have checked wires/crimping etc all ok, all I can test is circuit and for that component there is no circuit,
    so the fastest solution now is to buy new motor ( 😥 ) running out of clean socks, 😳 will let you know outcome in a few days
    again many thanks for to all in this excellent forum, saved me cost of call out 😀
    cheers
    john
    #144075
    Simon46
    are you using a multimeter set to ohms?
    Simon.
    #144076
    Hi Simon
    I was using little ohm meter , but set on circuit test and got nothing.
    when on ohms I get nothing at all.
    am I reading it right??
    cheers
    john
    #144077
    😀 replacement motor arrived today as promised, fitted in five minutes and machine working pefectly.
    spot on diagnosis guys 😀
    thanks to an excellent forum and good luck to the rest of you
    #144078
    Dave_Conway
    :tup:
    Thanks for letting us know John.
