Re: Indesit WD12 uk
Problem with the water level control system. Air collection bell may be choked, air hose blocked, trapped, pinched or even holed. The pressure switch may be faulty. Wiring between switch and control board may be faulty. Control board itself may be faulty.
So, just a few possibilities 😀 . If you’re not sure how to proceed, time for pro help – click the link below.
Power off if you are going to investigate.
