INdesit wd125
  • #18844
    mikey_G_2000
    Hi there.
    I wonder if anyone can help me. We have had an indesit wd125 washer dryer for about 4 years and have had no trouble from it whatsoever but the other day, shortly after starting a program, it stopped working. The motor hums but doesn’t turn the drum, the dial clicks round continually and the on off switch flashes 10 times. I have heard that this tells you the fault code but there is no info online as to the fault that 10 flashes indicates.
    Please help.
    Many thanks,
    Mike.
    #180641
    Dave_Conway
    Re: INdesit wd125
    Hi Mike,
    Using the search facility here:
    http://www.ukwhitegoods.co.uk/modules.p … ile=search
    Search for “F10” (without the quotes) and pick out all the Indesit and Ariston ones, plenty to go on there 🙂
    #180642
    mikey_G_2000
    Re: INdesit wd125
    Hi again. seem to have resolved issue with F10 error – three big blockages. Whilst I had it open I checked the pressure sensor and the circuit board and all seems fine. Draining sounds to be happening and pump is going but th dial is still clicking around. The flashing has gone down from 10 to 1. Any idea what this means as the mashine is still unusable. Have reset it – (i think) but starting to get frustrated.
    Your expertise is greatly appreciated.
    Many thanks,
    Mike.
    #180643
    Dave_Conway
    Re: INdesit wd125
    If ther’s one flash then it’s F01, there’s a few posts about that as well 😉
    Motor control problem possibly.
