indesit wd125 dryer stat
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts indesit wd125 dryer stat
  • #65386
    delta01
    hi does anyone know the part no for this stat please its the early white one with spade connectors ser. no 307108513 pnc 2953217
    thanks john
    #360313
    Re: indesit wd125 dryer stat
    You need to be more accurate with your details. 😉
    I am guessing you mean a WD12S there is no WD125. The commercial code for the WD12SUK is 25538 which also does not match any of the numbers given.
    A WD12S does however have a circular, spade terminal NTC (not stat).
    Part number is C00080767.
    delta01
    Thanks Jim i put the error down to failing eyesight no wonder i could not find the parts on qualtex etc
    #360315
    delta01
    Hi again Jim sorry to bother you, do you know which way the wiring to the fan motor and flying lead from heater protector go, one is black and the other is blue i am not familiar with these earlier models and failed to note which way these two leads went
    #360316
    PM me an e-mail address and I will send you some stuff. 😉
