indesit wd125 error code?? three flashes
Home Forums Public Support Forums Help And Support Washing Machine Help Forum indesit wd125 error code?? three flashes
  • #10247
    aRTy
    After looking thru the forums I cannot find one relating to the wd125 three flashes code anyone help??
    #139222
    Re: indesit wd125 error code?? three flashes
    Water temperature sensing problem usually 😉
    #139223
    aRTy
    any remedies??
    #139224
    Dave_Conway
    Check the connection to the temp sensor with the power off of course :zap:
    If you’re unsure, please call an engineer, repairs@ should provide one 😀
    #139225
    andy2
    As Dave says its almost certainly a OC thermistor / wiring fault.
    Easist way to check is to slip the plug of the thermistor and measure (using a multimeter) the resistance across the plug terminals. If there is no open circuit (broken connection) you should get a reading of about 13k ohms through the module.
    The thermistor itself should measure about 24K ohm at room temp.
    :zap: DONT FORGET TO PULL OUT THE MAINS PLUG FIRST :zap:
