indesit wd125 not drying
  • #22130
    bendaireboy
    Hi boy’s any ideas on wd125 indesit not drying Ive checked all meterable part’s.Would it be the eeprom or p.c.b or both,any suggestion’s would be good[sensible one’s you lot!!!!!!]
    #193749
    Re: indesit wd125 not drying
    Can you elaborate a little more please?
    Does the water flow? Does the element heat up? Does the pump work? Any power to these things? Have you inspected and checked the module and its connectors?
    #193750
    bendaireboy
    Martin everything meters ok ie correct resistances but no power on dry from board, board and components visually checked but no apparent damage,and the m/c works fine on wash but no dry nige
    #193751
    I’ve got one of those at the moment (a WDE12UK in fact) It tumbles and heat OK but won’t let in water or drain 🙁
    I’ve ordered a new Module in the fervent hope…..? :rolls:
    #193752
    bendaireboy
    ok i will do the same and let the site know of result,thanks
    #193753
    Like Martin ask you…
    Martin wrote:Can you elaborate a little more please?
    Without those details who can help you or advice… :rolls:
