Indesit WD12s – nothing happens unless door lock bypassed
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WD12s – nothing happens unless door lock bypassed
  • #14513
    bbm
    I have an Indesit WD12s Washer/Dryer. When any program is selected nothing happens except occassionaly the dial will rotate and I get 11 flashes on the on/off light. I have tried the usual reset procedure for Indesit machines but still nothing.
    I then found that the door lock wasn’t being activated – tried a new door lock – still nothing. Measured 240v on each of the two inputs to the door lock and 0v on the output. I am guessing that one of the inputs should be at 0v to activate the lock – it is a bi-metallic strip with a small heater underneath. If the lock is over-ridden manually then the machine begins the program as normal, although I have not run through a whole cycle.
    What activates the door lock – I assume it is controlled direct from the CPU but is there anything else that would prevent it being activated?
    #159717
    Re: Indesit WD12s – nothing happens unless door lock bypasse
    11 flashes is ‘supposed’ to signify that the pump is faulty. The PCB does auto test most components before the machine will run, however these machines have such troublesome, unreliable electronics that the fault codes are at best a first place guess in most cases 😥
    Note to the general public
    Live testing of the machine is not advisble. :zap:
    #159718
    bbm
    Thanks for the reply.
    Pump runs fine when door lock bypassed.
    Is there anything else that would stop the machine starting?
    If CPU is at fault then not really worth fixing although machine only just over a year old (warrany expired 2 months ago!!)
    #159719
    Apart from checking and if need be tightening all the connections on the module ( with the plug removed of course 😉 ) not much else you can do. Welcome to the world of the disposable washer, courtesy of Indesit. 😥
