Indesit WD12S UK
  • #77925
    barneysbull6
    Got an Indesit as above where the timer just clicks round. Does nothing else, now water let in or motor movement. Lifted machine up, strong guy, and found one of the motor carbon brushes on the floor, ruined and no chance of putting back. Would the absence of this brush cause above symptoms or is more likely to be door micro switch as it used to be in eons ago on washing machines :rolls:
    #403905
    Re: Indesit WD12S UK
    Check the motor out first strong guy. 😀
    #403906
    barneysbull6
    Would reckon that that the motor would be kaput if its minus one brush. Would that cut out all operations of the machine other than timer clicking round? Where in Hampshire are you? Lived in Pompee for many years b4 going north to Scouseland
    #403907
    barneysbull6 wrote:Would that cut out all operations of the machine other than timer clicking round?
    Oh yes! In fact any malfunction of these will make the timer knob go spinning. 🙁
    barneysbull6 wrote: Where in Hampshire are you?
    The posh part in the north of the county.
